Re: Aux tank neck needs straightened
Posted by Brownie 450 on September 21, 2009 at 04:04:57 from (66.43.241.141):
In Reply to: Aux tank neck needs straightened posted by Mike CA on September 20, 2009 at 20:44:34:
I would make an "L" shaped device out of 3/4 inch wide by 3/8 thick steel stock about 18 inches long. Bend a 90 degree on one end of the stock--either cold or using a little heat--& then use a hacksaw to cut off small increments until the "tool" will fit into the filler neck. When the proper dimensions have been arrived at, clamp the tool in a vise with the tank far enough from the vise jaws to get a small hydraulic jack between the tank & vise jaws with a 3/4 inch board to cushion the tank top. Try jacking the tank away from the vise with the tool on the side of the tank that has the dent.
Alternate method would be to use a slide-hammer puller--don't know if there would be enough offset on the end of the slide-hammer.
