Under the hydraulic lever there is a bolt with a 1/2 in head that stops the lever from moving to lower the implement. Make sure the bolt is screwed down for enough for the lever to go into the float position. There should be four positions on these levers. Top-lift, middle-neutral, down one-lower and down 2-float. But if that bolt is up too high it will stop the lever before it gets to float position. Now having said that, an 806 is getting some age on it and you might need to check out the actual valves. If they need to be rebuilt, that could be a problem. That's the problem I am having on a 966.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
