Re: 806 hyd valve question One way cylinders
Posted by MeanGene1 on September 21, 2009 at 08:55:29 from (204.14.185.206):
In Reply to: 806 hyd valve question One way cylinders posted by railhead on September 20, 2009 at 18:05:33:
We used to run a "steerable" plow on our 706D's, tractors had couplers at the rear and both sides. There was a sideshift in the hitch to fine tune the plow position horizontally, with a double cylinder plugged into the rear ports, and a single cylinder at the rear that raised and lowered the back of the plow via the trailing wheel, plugged into one of the right side ports. The sideshift worked off the left lever, trailing wheel off the right, worked just fine- pull back for lift, push ahead for gravity down.
