Re: I think I goofed. Belt pulley problem...
Posted by Mr. Mayor on September 21, 2009 at 10:11:44 from (12.155.240.215):
In Reply to: Re: I think I goofed. Belt pulley problem... posted by wayne in mn on September 20, 2009 at 21:02:25:
Wayne, I have a a leak at the pulley flange but the oil is coming out past the oil seal. I put a new seal in when I went through it but didn't take my usual cut off of the shaft to clean it up. So, all I want to do is pull the driven shaft out without disturbing the drive shaft. By your post and the parts book this seems to be possible. Correct??
