Re: MD will not run on Diesel
Posted by M Diesel on September 21, 2009 at 10:54:47 from (12.24.61.12):
In Reply to: MD will not run on Diesel posted by Lyle Jorgenson on September 20, 2009 at 18:17:38:
Without pressure on the gauge, it ain't going to happen.
They will sometimes run for several minutes with the fuel shut off, living on fuel in the filters.
Check the shutoff valve under the tank (been there done that). Then bleed the AUX filter. Start it and then bleed the primary filter (which is pressurized). Let us know if it still don't fire.
Direct starting will kill a Bendix is short order, and those heads were never intended for cold starts. It a matter of time in both cases.
