Re: What is HyTran Hyd. Fluid?
Posted by scot in pa on September 21, 2009 at 12:19:24 from (12.171.162.28):
In Reply to: What is HyTran Hyd. Fluid? posted by WEL(TN) on September 20, 2009 at 09:47:09:
We used some cheap off-brand hydraulic/transmission (Hy-Tran comes from Hydraulic Transmission, referring to hydrostatics and powershifts in construction equipment) fluid one time, and replaced every hose on the backhoe twice within the month. Think it was Pitt-Penn. We rarely use actual CIH oil but we do stick with the name brands. Shell, Pennzoil, Valvoline, Mystic/citgo, NAPA, someone with a reputation to take care of. And a warranty beyond replacing the bad bucket of oil.
Case construction also has an "HTF" or "HTO" additive that you mix in a certain ratio with 10w-30 motor oil.
