Ever try a W9 carb? A 281 should use a 27 or a 29, providing it has a close to stock compression cyl pressure. With high compression, your air speed and the amount of air will be increased. If it makes good power at 540, it should have a 15to 25 hp "torque curve" when you pull it down from 540 to 400 to 350 pto rpm. An engine setup to run high rpm wont lug at 1500 rpm or less than one that was setup for 1200 engine rpm to say,,,up to 1800 rpm. Huge difference in the two setups. Chad
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on
... [Read Article]
Latest Ad:
[More Ads]
