Re: Farmall 460 PTO question
Posted by Ksfarmmer on September 21, 2009 at 14:02:53 from (68.103.49.183):
In Reply to: Farmall 460 PTO question posted by Erik MN on September 21, 2009 at 10:06:38:
Congratulations on your accomplishment! Sounds like it will be a fine tractor for you. We had a 560 when I was growing up. I think the PTO lever design is similar. It needs to be locked down in the OFF position or the PTO may continue to rotate. I am guessing you just need to lubricate and loosen all the linkage to make sure everything is freed up properly.
