The neck is only soldered on, so you can't reef on it too much. One idea did come to mind. You could use a piece of pipe, probably 2" or 2 1/4", something that would fit over the OUTSIDE of the neck, and large enough to go over the solder lip at the bottom, but snug enough to fit almost snug. DO NOT, use too much force, and go a little at a time. Too much force, and you will break the solder joint.
The really correct way to fix this would be to take the neck off, repair the bend in the tank, then solder the neck back on.
alot of work for something that may not bring that much return on time invested. However, you never count the hours in a labor of love......
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
