Re: IH 674 Diesel - Using/Blowing oil
Posted by jimb2 on September 21, 2009 at 16:49:56 from (99.240.236.11):
In Reply to: IH 674 Diesel - Using/Blowing oil posted by ClarkR on September 21, 2009 at 05:06:38:
The 674D has a D-239 German Diesel engine in it. As someone else said the German Diesels like to be worked hard.
How many hours are on the tach? These German Diesels are good for well over 15,000 Hrs if proper maintenance has be performed. A couple quick checks:
1)check for oil leaking out the bottom of the clutch inspection plate. Could be loose rear main seal.
2)There was a change to the older D-239 with the crankcase vent tube as oil would leak out the crankcase tube if the tractor was on a steep incline or right side on downward slope.
JimB
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
