Re: TA will not shift out of low!
Posted by D Slater on September 21, 2009 at 19:12:08 from (71.164.37.9):
In Reply to: TA will not shift out of low! posted by Elvared on September 21, 2009 at 16:19:36:
If you remove the t/a linkage pins from the shaft closest to operator and the shaft will move clockwise and counterclockwise freely for a short distance there's a problem with the t/a clutch. Its not holding for some reason, maybe stripped the splines on t/a shaft that center of t/a clutch plate goes on if it done it at once with no noise. Also check for oil at drain holes on bottom of center housing in case a seal let oil get to clutch. Unless your linkage happend to be bond up a tear down is needed.
