Re: Farmall A Steering Stiff
Posted by gene bender on September 22, 2009 at 02:28:34 from (67.55.226.179):
In Reply to: Farmall A Steering Stiff posted by Greg Flugum on September 21, 2009 at 11:36:41:
Jack the front up. I would remove the tie-rod ends so i could tell where the hard steering is coming from. Probably the spindles arent getting grease at the bottom. With the wt off you should be able to get some grease to come out the bottom. This is usually the case when the A gets hard to steer.
