Re: fluid in tires
Posted by redblood on September 22, 2009 at 09:20:15 from (64.12.117.13):
In Reply to: fluid in tires posted by jdetig1 on September 22, 2009 at 08:53:32:
It will only cause the rim to rust IF the tube leaks. You can drain them out refill. But where ever you drain the chloride? off to will not grow anything.
Weight depends on tire size.
I believe a 13.6x38 it adds about 800# per tire.
The tube can be refilled with what ever liquid you choose. But make sure it is something readily available. In case of a puncture.
