Re: Generator on M
Posted by JMOR on September 22, 2009 at 10:52:27 from (72.181.156.161):
In Reply to: Generator on M posted by 728171 on September 22, 2009 at 07:22:15:
pete 23 said: (quoted from post at 13:33:50 09/22/09) Just to add something here to the very good explanation of the combination current voltage regulator, not all 3rd brush generators had the adjustable option so you cannot move them. And the load terminal on regulator is live all the time same as battery terminal on regulator so you will still have lights without engine running. Then also realize when moving 3rd brush closer to main brush you are increasing current flow through field, thus through voltage regulator points and therefore may cause short life of the points in regulator. Later new replacement generators were of the shunt wound version(two brush) and performed much better.
Yes, as pete23 said..........my SMTA has a non-adjustable 3rd brush generator.
