Re: fluid in tires
Posted by Hugh MacKay on September 22, 2009 at 12:30:25 from (209.226.247.110):
In Reply to: fluid in tires posted by jdetig1 on September 22, 2009 at 08:53:32:
jdetig: If you don't have leaks calcium chloride will not rust your rims. Change the screw in valve stem every 5 years and rims will last 50 years. That is right, I have 4 - 50 year old rims that have had chloride in tires since new.
