Re: Rebuild cylinder head?
Posted by David G on September 22, 2009 at 16:43:34 from (216.203.121.248):
In Reply to: Rebuild cylinder head? posted by Randy D McClenahan on September 22, 2009 at 16:26:52:
The valves are sealing OK if the compression is good. There is probably some wear on the guides, which will also cause oil consumption. I do not know what type of valve seals it has. It would be prudent to go through the head if you are replacing the rings.
