Re: fluid in tires
Posted by Gurneejoe on September 22, 2009 at 17:17:21 from (67.162.37.195):
In Reply to: fluid in tires posted by jdetig1 on September 22, 2009 at 08:53:32:
In a 13.6X38 tubeless tire if the fluid is above the level of the rim inside they hold 110 gallons. That times whatever a gallon of disolved calcium chloride weighs. Estimate 8 pounds per gallon. This liquid does not evaporate much if at all. I had some splash on to the shop wall one time and the droplets were still liquid to the touch a year later.
