Re: F240 Fast hitch drawbar and PTO distance?
Posted by Hugh MacKay on September 22, 2009 at 17:45:58 from (209.226.247.183):
In Reply to: F240 Fast hitch drawbar and PTO distance? posted by dep on September 22, 2009 at 08:14:10:
dep: None of the fast hitch crossbars on any models give the 14". They were all designed for adding a sort of triangle shaped plate. They spanned three hole on the cross bar coming back to about 3" at drawbar pin. This allows you to turn without binding as you would get pinned direct to cross bar.
You can make one out of 5/8" or 3/4" steel plate. The factory ones were 5/8" on 200, 230 and 240, 3/4" on larger tractors. I've seen them made out of 1" on big tractors.
