Posted by Bill in IL on September 22, 2009 at 18:02:16 from (98.108.64.176):
In Reply to: Re: Generator on M posted by JMOR on September 22, 2009 at 14:01:24:
Thanks for checking your old manuals. What type of manuals do you have. I only have the I&T manual and it doesn't even mention the Generator.
I have not given up on it yet but raising the output voltage to within an acceptable level of 7.2 volts would lower the current to 11.6 amps.... still barely in the range but it would charge the battery better. I keep having to supplement it bout once a month with the charger or hand crank it once in a while.
When I get outside tonight I want to check it with the ampmeter and see exactly what the output is cause it goes to discharge on the low lamp setting too.
Guess I see why so many convert to 12v. My wd is 12volt and everything is fine there even running a spotlight with the headlights.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
