Re: Rebuild cylinder head?
Posted by John B. on September 22, 2009 at 19:11:05 from (38.114.64.145):
In Reply to: Rebuild cylinder head? posted by Randy D McClenahan on September 22, 2009 at 16:26:52:
If you're going to rebuild the bottom side (new rings) have the top side (valve job) done also.
The new rings will create more compression and you don't want to loose it with old or leaky valves. Let a lone with worn valve keepers that may let go and drop a valve on top of your piston.
Just take the head and lay it on it's side on the work bench and pour some ATF in the intake and exhaust ports and see if it leaks by the valves. It most likely will!
