Re: Aux tank neck needs straightened
Posted by Mike CA on September 22, 2009 at 22:55:30 from (99.28.152.102):
In Reply to: Aux tank neck needs straightened posted by Mike CA on September 20, 2009 at 20:44:34:
Janicholson said: Fill with water.
Use plastic film under the lid.
Use shop air pressure to pressurize the water.
Do not use just air, it can be a bomb. The water reduces the amount of pressurized air, and makes the process safe. JimN
So is the pressurization supposed to take care of the bend, or do I use the L bar in conjunction with the pressurization? If so, how do I accomplish that?
I'm not quite sure how to pressurize it in the first place. Do I pressurize it via the valve on the bottom?
