Re: Rebuild fan on A or get new sealed bearing type??
Posted by ScottyHOMEy on September 23, 2009 at 04:43:14 from (70.105.228.226):
In Reply to: Re: Rebuild fan on A or get new sealed bearing type?? posted by WOK on September 22, 2009 at 18:08:19:
Maybe somebone is making the whole unit with bearings, the same way they are stil making the old-style. I did mine with a kit that I got from Mark's, that includes the bearings, shaft and hardware. The existing shaft isn't suitable because of the spiral in it that carries the oil, and the spacing is different since you no longer use the oil slinger. It uses the existing reservoir, and you have to cut the standpipe and the cone out of the inside of it for everything to fit in. Your existing fan blades bolt on the front.
