Re: Super M points
Posted by MHMalcolm on September 23, 2009 at 06:17:48 from (66.66.148.252):
In Reply to: Super M points posted by jeffalex2 on September 23, 2009 at 03:50:02:
You may have already done this, but make sure coil polarity is correct. If you have a positive ground system, the wire from the distributor goes to the positive coil terminal. It needs to be connected to the negative coil terminal if you have a negative ground.
