Re: Generator on M
Posted by Bob M on September 23, 2009 at 06:34:11 from (151.190.254.108):
In Reply to: Re: Generator on M posted by Bill in IL on September 22, 2009 at 12:58:45:
Try measuring voltage across the battery after making the connection to the VR "load" terminal and see what you get.
If the voltage is still low, it can adjusted by GENTLY bending the spring hanger on the VR relay. Increasing spring tension increases the voltage setting.
But be careful! Only a slight change in tension causes a significant change in voltage. Also make sure the battery is fully charged and the charging system is up to temperature (has been charging for 5 - 10 minutes) before attempting adjustment.
(Note - The VR relay is the one with its contacts held CLOSED by spring tension.)
