Re: Main transmission shaft backlash
Posted by Gmercer on September 23, 2009 at 10:22:15 from (24.230.119.203):
In Reply to: Main transmission shaft backlash posted by Janicholson on September 23, 2009 at 07:29:10:
Thanks, I Googled "measuring backlash" under images and saw several examples of the procedure using a magnetic base dial indicator. I have one so I will check the backlash with it. I havenn't checked the teeth yet but will probably set it according to the wear pattern. I think I'll have to jack the back of the tractor half up in order to turn the ring gear. Not sure if I need both wheels off the ground or just one. I'll try to locate some blue paste. Gmercer
