A rear plate and frame rails from a 460/560 would make the job easier. To get hydraulics I assume that you would need to use the pump on the combine engine. In that case you need to fabricate your own front mounts.
A larger problem may be that the two engines are designed to run at different RPMs. Rated speed of the 400 is 1450. Minimum overload speed of the six cylinder is probably 1800 - 1900. Rated speed somewhere in the 2300 - 2800 range.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
