Re: farmall 400 wants a 301
Posted by ChadS on September 23, 2009 at 16:23:55 from (4.224.78.204):
In Reply to: farmall 400 wants a 301 posted by redblood on September 23, 2009 at 10:35:48:
560 flywheel, 560 pressure plate with live pto hub removed. Then take a 560 clutch disk, have a M clutch spline installed instead of the 560"s.
M and 560 use the same backspacing from the rear engine plate to the back edge of the starter ring, I belive its 4 inches.
Im not sure on the starter ring,,, Id belive the 560 should work,, because,, I can put a 450 flywheel in a M and still use the 2 bolt M starter without changing the starter ring. So,, Id say you can use the stock 400 starter and the clutch setup from the 560 and bolt the two halves together. 560 frame rails bolt right up, and you can use a M-450 bolster if you decided to keep the 400 tin, with the overhead steering shaft. Hope this helps. ChadS
