Re: 1942 A with mag will not shut off
Posted by Red Dave on September 23, 2009 at 17:04:15 from (98.235.15.235):
In Reply to: 1942 A with mag will not shut off posted by tackhammertime on September 23, 2009 at 16:59:05:
Battery, generator and regulator have nothing to do with starting or stopping the engine when it has a magneto.
To stop the engine, ground the small (About #8 size) screw head that sticks out the side of the magneto. This screw connection should be wired to the Run/Stop switch and nowhere else. When the switch is pulled out, the engine should run, when you push it in, it stops. At least that is how the original worked.
