Re: Starter solenoid for my 400
Posted by AJB450 on September 23, 2009 at 19:27:51 from (98.115.103.184):
In Reply to: Starter solenoid for my 400 posted by SDE on September 23, 2009 at 06:29:25:
SDE,
I had a similar problem with my 300 utility. Replaced solenoid with a known good one and same problem. Would sometimes just click the starter solenoid and sometimes the starter would work. Problem was the combination ignition/starter switch. Put a 350/450 style starter switch in the cigerate lighter hole and no more problems. So it could be that your starter switch has a bad contact.
Al
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
