Posted by farmerwannabe on September 23, 2009 at 21:59:20 from (68.188.241.80):
Well, after reading your responses and asking a few more questions, I"m going to give switching the battery so it"s 6-volt positive ground instead of the negative ground it currently is. I"m hoping it will charge, but we"ll see!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
