Posted by Wardner on September 23, 2009 at 22:04:08 from (4.154.241.177):
In Reply to: Belt pully posted by rbean on September 23, 2009 at 20:32:43:
Yes, with the exception that the engaging lever will be on the opposite side. It is welded but you can cut the welds (with a grinder or hacksaw) and reattach to the right side where the 450 lever should be.
If you have a welder, it shouldn't take more than ten minutes. You will need a little right angle clip to hold the pull rod. It attaches to the sheet metal surrounding the hydraulic reservoir with two sheet metal screws. The screw holes or clip might already be on your tractor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
