Re: Got the belt pulley inards out. Bearing question...
Posted by J.J. from Afton on September 23, 2009 at 23:27:38 from (24.118.175.64):
In Reply to: Got the belt pulley inards out. Bearing question... posted by Mike CA on September 23, 2009 at 23:14:10:
You can tell the bearings are bad if you see any chipped or broken balls or rollers. Also if there is any rust or corrsionin the races or on the balls/rollers themselves it should be replaced. Another way to tell is if there is any resistance or friction when you spin the bearings in your hand than theres either damage or foriegn matter in the bearing. If the spin smoothly and freely they are good to go.
Sorry for long answer but hope this helps you.
-Jordan
