Posted by Pete in Holland, MI on September 24, 2009 at 05:27:43 from (63.144.115.203):
In Reply to: Rusty gas tank on an M posted by Marty from MN on September 23, 2009 at 18:56:24:
Couple options:
1) Drain the gas and allow it to dry out completely. Do the stone tumbling thing. If you don't have a cement mixer, have heard of folks tying it on to the wheel of another tractor then go out for a ride. Dump the stones, then use an air hose to keep the stuff stirred up, and a vacuum cleaner down inside to vacuum up all the crap.
2) As mentioned earlier, I have also done the copper tube trick. Dropped the fuel bowl out of a couple tractors, inserted and soldered in a 2" piece of copper tubing. The tubing is pinched shut on the top, and cross drilled with a couple dozen 1/16" holes. This will allow scale to accumulate in the tank and not plug up the flow of gas. Pieces small enough to get thru the 1/16" holes will settle out in the glass.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
