Re: Additional reservior for hydraulic top link - Super A
Posted by mkirsch on September 24, 2009 at 05:45:22 from (64.80.108.57):
In Reply to: Additional reservior for hydraulic top link - Super A posted by SteveNH on September 23, 2009 at 16:10:54:
Steve, with a power beyond, you need to do BOTH:
1. Run a line to the reservoir from the OUT port. This is to give the fluid somewhere to go when you're using the valve with the power beyond.
2. Return to the touch control from the POWER BEYOND port. This is so that the oil can still flow through when you're not using the valve, and the touch control will work.
If you don't do both, then the hydraulic system will get damaged because the fluid has no place to go.
The extra reservoir gets connected to the fill port on the left. If you hook it anywhere on the bypass block, all you will do is blow hydraulic fluid everywhere.
