Re: UPDATE: DIESEL EXPERTS! Look here!
Posted by pete 23 on September 24, 2009 at 11:31:05 from (173.87.8.73):
In Reply to: UPDATE: DIESEL EXPERTS! Look here! posted by charles todd on September 23, 2009 at 18:00:49:
A leaking nozzle will knock like crazy, so easy to check because you just have to pull the lines off nozzles,(commonly refered to as injectors) crank engine over a few times and observe. Good ones will not push any compression out at all, shot one will shoot right out and worn ones may push a little out, and you don't have to bleed anything, just screw them nuts back on. Have seen many drop the pintle from nozzle tip which can give you both a fuel knock and a mechanical knock from it becoming imbedded in top of piston. Be interested to see what you find, could be any of suggested remedies.
