Posted by Harold H on September 24, 2009 at 18:48:08 from (69.40.30.158):
In Reply to: Reversed SM posted by deano4863 on September 24, 2009 at 17:39:39:
It was apparantly reversed to operate under a low drum picker. The only additional parts you need to restore it to normal forward operation are a set of regular shift forks. Just flip the differential, mount the forks, mount shift lever in opposite side and it is reversed. You will need to turn the front wheel around so it will caster and if the rear tire treads are backwards, swap sides with the tires so the lugs will be correct.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
