Re: Pos or Neg ground question?
Posted by Hugh MacKay on September 25, 2009 at 01:27:19 from (216.208.58.117):
In Reply to: Pos or Neg ground question? posted by TedD17 on September 24, 2009 at 22:44:49:
Ted: All IH 6 volt tractors were positive ground from the factory. They can be changed, so it's only a guess what you might have 60 years later.
Usually nothing has been changed, just some bozo put a battery in backwards. Which way does the amp gauge move when you turn on ign switch? If factory and battery is in backwards, gauge will go pos. If it has bee changed to neg ground, gauge should go neg.
