Re: Timing a Farmall M Diesel
Posted by jfrankhash on September 25, 2009 at 08:35:35 from (12.213.224.36):
In Reply to: Timing a Farmall M Diesel posted by farmall flunkee on September 25, 2009 at 07:21:23:
I can't help with the timing question, I have the same trouble. Howefver, I solved the "black smoke" problem by cutting off the diesel fuel under the tank when I switched back to gas before shutting down. It appears that I was getting some diesel blow through while on gas, and it remained in the cylinders when I went to start it the next time. Helps with the starting, but is still slow.
