The expander spacer is a segmented split ring. It is flexible when not in place. It is put into the oil ring groove of the piston first. The ends of this expander spacer are butted together. At this point the expander Spacer tries to get out of the groove, and is a bit unruley. A rail is next wound onto the expander, to the top of the groove, carefully assuring that it is sitting on the ledge formed by the expander spacre segments, and its end gap 90 degrees away from the butted ends of the Expander spacer. Next the lower rail (they are the same, this just refers to its position) is wound into the groove at the bottom of the groove. Again this is resting on the ledge of the expander spacer. The resulting tension on the rails from the expander spacer fills the groove, and makes the rails pretty hard to move with your fingers when the piston is out of the cylinder. The ring compressor needs to be good to compress the rails evenly as they are pushed into the bores. If the system as is has loose expander spacers and loose rails, it will burn oil. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
