Re: SH Venturi
Posted by D Slater on September 25, 2009 at 16:33:50 from (71.164.37.9):
In Reply to: Re: SH Venturi posted by deano4863 on September 25, 2009 at 15:52:18:
Without knowing what is modified in engine or carburetor and what tractor will be used for, I have no opinion. If it run okay put the same one back. If you can't see the D 27 or whatever on it. A 23 hole is smaller than 3/4 inch dia. and a 27 is roughly 1/8 inch bigger.If you have a 3/4 inch bolt it won't go in a 23 and has a good bit of room in a 27. Far as I know all M tractors call for a D27 venturi.
