Re: Washing tractor
Posted by Jim Broughton on September 25, 2009 at 21:32:52 from (4.243.28.218):
In Reply to: Washing tractor posted by 7lazy77 on September 25, 2009 at 20:47:47:
If it has a magneto, you might want to cover that, but otherwise it should be OK...I would add some "Dawn" detergent to the pressure washer, you"d be amazed at the amount of grease and dirt that stuff will take off !!
Best of luck on "er !
Jim B.
