Posted by JMOR on September 26, 2009 at 07:37:01 from (72.181.156.161):
In Reply to: 6 or 12 volt coil ? posted by soybeanjoe on September 26, 2009 at 07:17:56:
Genos said: (quoted from post at 10:17:56 09/26/09) How can you tell the diff. from a 12 volt or a six volt coil thats not marked? what test do you do?
You can use just about any coil on a 12volt system IF you use the correct ballast resistor with it to establish proper current (about 4 amps stalled).
The 'true' 12volt coils , such as NAPA IC14SB (3.25 ohms), which require no ballast resistor can be identified by measuring their primary resistance with an ohm meter. They will measure between 3 & 4 ohms, where as the 6v coils will measure about one-half of that & in some cases even less.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
