The belly mower will not need the over-running clutch. Those 3 small blades just don't get enough momentum going to need it. I've got a 72" on a Farmall H and the mower belt will slip before the engine ever pulls down. The H is rated at 26 horsepower on the PTO. I'm guessing your 140 is somewhat close to that, so the 72" mower shouldn't be a problem so long as you don't let the grass get too tall before you cut it.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
