Re: 6 or 12 volt coil ?
Posted by John T on September 26, 2009 at 12:37:32 from (66.244.97.31):
In Reply to: 6 or 12 volt coil ? posted by Genos on September 26, 2009 at 07:17:56:
Most typical 6 volt coils will have a primary resistance as measured between its little + and - terminals in the range of 1.5 ohms (1.25 to under 2),,,Most typical 12 volt coils have around 3 ohms (2.5 to under 4)......The reasons for those values is to limit the amount of current the points have to switch on and off in the 4 amps range otherwise they can burn up prematurely plus a weak or no condensor likewise makes them burn up prematurely.
Is there a ballast resistor on the tractor?? If it was 6 volt with 6 volt coil there wouldnt be one.......If a 6 volt tractor like an H got converted to 12 volts, it needed EITHER an external ballast with the old 6 volt coil or else a new full true 12 volt (some call internally ballasted) coil......
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
