Posted by glennster on September 26, 2009 at 12:45:51 from (24.14.63.246):
In Reply to: Farmall H engine kit posted by oliverkid on September 26, 2009 at 10:06:15:
if you are having the crankshaft ground, order everything but the main and rod bearings, have the machine shop get the bearings when they cut the crank. that way you womt have an extra set of bearings laying around that you cant use (like me)
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
