update on 806 hyds...
Posted by railhead on September 26, 2009 at 18:57:19 from (205.237.134.3):
Well the 806 hyds that would not allow a one way cylinder to release (hesston 1014 haybine) turned out to be a broken roll pin in the lever shaft that works the valve...it would lift but not allolw to bleed back. Boy taking that assembly apart in a elbow banger cab is a real pleasure. You cannot get to anything in the elbow bangers...especially if you are 6'2" and 230 lbs...but it beats setting out in the sun. thanks a to all replies.
