If the plugs are "dry", one sure way to tell if you have it set up right is to spray a small amount of starter fluid down the air cleaner tube (before anyone flames me for saying this, if he has flat pistons, he has about a 6 to 1 compression ratio...this will not hurt his engine). Now, if it "pops" a couple of times with this, open up the carb to about 2 1/4 turns (vs. the 1 turn). Then shoot another hit of starter fluid down the filter tube. If everything is right it will start and most likely run, assuming the carb has been put back together correctly and the float is set right. BobG in VA
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
