Re: How fast does 6 volt starters turn over ?
Posted by gene bender on September 27, 2009 at 07:45:34 from (67.55.226.179):
In Reply to: How fast does 6 volt starters turn over ? posted by couv on September 26, 2009 at 19:04:14:
Start with the starter new brushes bearings and oil. Then clean the sw then 1ga cables and it will spin over like new. Take a sp reading of the batt cells to make sure the batt is in shape. The engine will spin great.
