Re: Question on 12V conversion
Posted by The tractor vet on September 27, 2009 at 07:51:02 from (76.212.226.51):
In Reply to: Question on 12V conversion posted by Tom Fleming on September 27, 2009 at 03:40:57:
The only thing here is that the org. Amp gauge is only a 20 amp gauge and if you have and alt. on it when she goes into full charge depending on the amp rating of the alt it will peg the gauge and i have seen them stick the needle . The light switch will take it as the higher the volts the lower the amp.'s
When i make a change from a 6 to a 12 i replace the main wire from the gen to the amp gauge and from the amp gauge to the starter switch with a 8 ga. wire as the old 10 ga. will work but i feel better with the bigger wire
. But i am the type of guy that when fabbing something if 3/16ths would work then 3/8ths is better .
