Re: 100 turns over, wont start
Posted by gene bender on September 27, 2009 at 07:59:31 from (67.55.226.179):
In Reply to: 100 turns over, wont start posted by couv on September 26, 2009 at 18:58:40:
I would remove all plugs then hook up #1 wire to a grounded plug. With sw on place finger in #1 hole hit starter sw and turn engine over and watch for fire at the plug when #1 hits compression. Thats the first thing i do when they tell me it wont start. If i have fire on compression it will tell me about timing and fire to the plug.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
